Oil From Dipstick Tube
Arizona
Hi i have oil coming out of the dipstick tube under normal driving RPMs but not when at idle would this be crank case over pressure? i think i need a new dipstick where would be a good place to get one?
Thanks
Is the oil coming out of the top or the bottom of the tube?
Top would imply that you have either a bad PCV or lots of blow-by.
Bottom would mean either your seal is bad or the tube is rusted through...
What engine do you have?
thanks should have been more clear it is coming out of the top and its a 2.3
That said I would do like above and just change the PCV valve but might even venture and do a compression test to get a general idea on engine health
