dangerousrangerous
- Feb 19, 2008
- Age
- 36
So I'm pretty good with cars. Just rebuilt the engine in my 83 mitsubishi starion turbo. And just waiting to get a few things back in before I drive it again. SOOO I've been driving my moms truck around. This morning I got in it and around 2200rpm I hear this knocking noise. It is for sure the rod bearings. Idle is wayy quiet. I check the oil and it is hella low. I had to put 3 quarts in it to fill it. My Mom told me when i started driving it that it hadn't ever used oil before but that it had been a while since she had had it changed. I never lost oil pressure so I didn't ever worry about it until the sound. So I stopped driving it hoping to maybe save the crank. I have in the past been able to fix knocking like this by dropping the oil pan and replacing the rod bearings from below the car. I am wondering if anyone has ever done this before on a ranger. Anyone know if the oil pan will even come off with the engine in the truck? I crawled under the car and it looked like it might be possible if you lift the engine up a few inches with a jack on the bell housing. In the case this is possible where is the cheapest place to get rod bearings? And if this isn't possible and my crank is trash what cranks can I use? only 01 and up 2.3L cranks? Sorry i'm a ford newb and i couldn't find anything with the search function.
Thanks,
Travis
Thanks,
Travis
