- Mar 12, 2011
- Edinburg, TX
- My credo
- Fix it till its broke!
That looks correct. This is no guarantee that the timing is correct. Incorrect timing can prevent the engine from starting. So can poor compression, weak spark, low fuel pressure, etc.
Also, the plugs are wet you say. Are you sure it is fuel and not oil fouling?
Also, check fuel pressure and timing. Timing can be checked while cranking.
He said they are not wet, as in dry. how did you check the pressure? If you do have fuel pressure it's possibly bad injectors since you have pressure and spark.
