My 93 with a 5.0L has been sitting for a while. I have been tinkering with it, and am getting an error code 63.
Given the error, and erratic idle, I assumed the throttle position sensor was bad. I put a new one on, and the idle was a little (not much) better. However, I am still getting a 63 error code.
Further research says there could be an issue with the right-side O2 sensor. I will check on that in the morning.
Does anyone have any suggestions as to what else the problem could be?
The engine is a 5.0L, wired as a '93, with an AOD trans. I am running a Mustang computer from a '91. The engine was newly built before the swap, and has about 25K miles on it - before being parked.
Thanks.
Thanks.
