- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
I think I've posted in this area of my Ranger doing a tractor pull from the beginning of September, the ol turbo Ranger put down 226', beat a 4.0L cherokee by 20', also beat two V8 Wranglers and two 4 cylinder Toyotas...
Anyway, I had a little axle wrap at the end and broke the rear yoke from contact of the D shaft side straps hitting the yoke, pierced the radiator with the fan (just a little hole), bent the drivers side leaf spring, and broke the passenger side plug welds on the diff!
Anyway, as I said in the title, if you are already there with the welder welding shock tabs on and spring perches, weld the tubes to the diff housing... even some non perfect welds will be better than nothing, I thought about doing it on mine while I was there a couple years ago but decided against it...
