brianballard1983
- Mar 7, 2010
i got a 88 with a 2.9 and 96,xxx actual miles. when i first start it up it runs great but after about 20-30 miles it gets a loud knock which is not constant it comes and goes but is there most of the time that sounds like it is in the valve train. i quickly decided drops in oil pressur was the problem and a faulty warning light. thus i put on a mechanical guage at first start i got around 50 lbs and 45 lbs during normal driving at idle it holds between 25 to 30. but still got this awlful pecking. i removed the valve covers for a closer look and found a total of 3 rockers way out of adjustment. after a turn of the wrench and some new gaskets still got the same problem and chattering valves when you accelrate or pull a hill this to comes and goes. i also had a cracked head or blowed gasket that i reparied with k&w block sealer (it works). but still got the knock rattle tick or whatever. really getting fed up someone please help.
