mrbeezroom
I have a 1994 Mazda B3000 ext cab and none of my turn signals work. They were working a while back, albeit very slowly and weak. They recently stopped working altogether. My 4-way emergency flashers are fine (even when I remove the flasher unit from the fuse box). I checked the fuse panel and the fuses seemed fine. Installed a new flasher unit and it had no effect. I believe there is only one flasher unit located on the fuse box. Headlights, brake lights, and windshield wipers/washers are all working. The right half of my instrument panel doesn't light up (been like that for a while), most likely a bulb.
The truck is completely stock except for a shell on the bed.
The 5-speed manual transmission has been replaced/rebuilt.
My backup lights don't work (most likely related to the transmission work).
