No Start Fuel Issue....
try prying off the cover of the relay and see if the points are actually moving and making contact(& also clean) when key is turned to run position. also pinch the points together and see if circuit closes and runs the pumps.
another thing you may wish to check regarding eec grounds:
continuity between pins 20, 40, & 60 on eec connector and the negative battery clamp(which is hopefully disconnected before removing eec wiring connector). these are all ground wires that the eec uses to supply the various systems it controls by grounding.
Ron and all. No luck with our wreckers but I was so lucky to see an ECM for that model in Ebay for $73.00. Hook it up right after work today and viola! It started like nothing ever happened. What a challenge. Thank you so much for the advice and guidance. I learned a lot from this. Hope to cross path with all of you again helping others to troubleshoot issues. This is an awesome day for me having it parked since fall. Love you guys.
Good work :icon_thumby:
Thanks for the update
Awesome! Glad it's fixed....Getting a thorn in your side fixed like that is an amazing feeling.
