TheCiscoKid
I did a duraspark conversion to my truck, used all new parts and got a 2150 carb. I had it running and was working on setting the choke and idle when one day it wouldn't start. Narrowed the problem down to the plugs not firing. I have tested the coil and replaced the duraspark box with a spare. The cap looks fine and the rotor is spinning. The coil, distributor and duraspark box all have 12 volts when they should and all grounds are fine. Last thing I can think of is the distributor it self. Any input? Thanks.
