2.3L ('83-'97) No shifting after solenoid pack (TCC, shift andreplacement
jthrash85
Providence, RI
Vehicle: 1997 Ford Ranger 2.3L, 4R44E automatic transmission.
Problem: Car is idling in park, I put into any gear nothing happens.
Process of Work Performed: Turned car off (battery still connected), Dropped transmission fluid pan, changed filter and installed new (refurbished) solenoids - 4 x shift solenoids, 1 x TCC solenoid and 1 x EPC solenoid, replaced pan with new gasket, torqued everything to spec, refilled transmission fluid with Mercon V (4-quarts), idled for 10 minutes, checked fluid level, shifted all gears with foot on the brake, re-checked fluid level, tried for a test ride. no movement in drive, reverse or lower gears (i.e., 3, 2). No change in sounds or anything. Car does not stall.
Internal diagnosis and questions: When I changed the solenoids I did my best to keep trans fluid from dripping on the solenoid harness contacts that plug into the actual solenoid valve, but chances are a few drops may have touched the connectors. I made sure all rubber o-ring gaskets came out with old solenoids and new gaskets were on the replacement solenoids. Based on the truck not responding to any change in gear I want to believe this is an electrical issue. I checked a few fuses (i.e., 13 and 16) and they were fine. The truck never jerked when I changed gears or made any odd noises. Just completely unresponsive to changing gears.
Thanks for your help!
