No power?
I am swapping a 92 4.0 into a 94 2.3 Ranger. I put it in and hooked up all the wiring with the 4.0 harness but I can't seem to gte any power anywheres. I hooked up all the grounds and and the battery is in there, as well as there is no blown fuses. Can anyone tell me what might be going wrong. Both trucks ran before I swapped them.
anyone got any ideas, ive researched but cannot find anything, im lost for ideas now
battery has like 12. something volts, terminals worked fine in the truck before, ill check that though. first thing that made me figure something was wrong was when i had the negative terminal connected i put on the positive terminal and there wasnt any spark or nothing, then i checked for power anywhere but nothing anywheres
ok tonight i found my problem and got the electrical all working it seems, motor turns over and everything, one more problem though, the fuel pump isnt working? now gotta find that problem, any ideas?
brandon
relay?,inertia switch?do you have power at the pump?
what was wrong with your truck in the first place?
Yeah, check relay/inertia swith, which is under the dash, almost under the carpet on the pass. side.
Yeah, check for power at the pump, if no power, you'll need to trace the wires back to where you have power.
main wire to the power distribution box was boken haha, i havent really had a look at the pump yet, it was late wheni finally got the other problem fixed.
thanks ill check those and let yous know the result, really appreciate it
brandon
