LARRYBOMB
I bought a '88 reg cab 2.9L auto tranny. I originally bought the truck because I needed a solid cab with a good title to put on a different frame. My brother gave me an abandoned project he started a long time ago. So I have Ranger frame with a 302 waiting for a cab.
Anyways I got the '88 for $500 and the previous owner replaced alternator, fuel rail, fuel injecters, IAC, map sensor, in-tank fuel pump, ignition coil and never could get it to run. So I got it home and first thing I do is hooked up a battery and turned the key to listen for fuels pumps. Nothing but the eec relay doing it's 2 clicks. I checked for power going to the inertia switch and had nothing. The inertia switch has a Org/LtBlu and Pnk/Blk wires. The org/ltblu comes from the fuel pump relay shouldn't that be power going to the inertia switch? I hooked up a test light and got nothing. So I put test light on + and touched the org/blu wire and light came on. So the org/blu wire is grounded. The fuel pump relay has ylw wire for constant 12v and there is a red wire for 12v with key on.
I have been reading different posts on the forum trying to get some ideas what to do. The truck's interior is pretty nice and the body is fair (not to rusty just some dents and clear coat peel). The title and odometer says 95,000 but you never really know if it's accurate. The motor does look fairly clean though. I do need a cab for my project but I'm not going to tear this truck up if it turns out to be a good runner. I bought a '90 2.3L 5spd over a year and a half ago for $450 and had to put a timing belt on it and have been driving it ever since. If the timing belt didnt fix it I was gonna use that cab. (lol my daily driver now)
