no power to fog lights
DennisH
Fort Wayne, IN
I have no power to my fog lights on my 94 3.0. I've checked the fuses under the dash and they all look good. Is there any other fuses I should check and where are they at? I've got power to the switch.
did you check power at the light. the bulbs might be bad. unlikely that both are bad but its worth checking
also. in case you didnt know. pre 95 you have to have your headlights on in order for your fogs to come on
The bulbs are fine. Just no power. I did find a fuse that's bad in the engine compartment. It says 20 on it and is yellow. Also found the relay for the fog lights but not sure how to check to see if its good.
