Currently I have no heat in the truck. No matter where you set the temp it is still cold, A/C works fine. 94 ranger splash 3.0, just had the motor out to reseal it and take care of a few other problems, not really sure if the heat worked before. Entire cooling system was drained. New radiator, fan, waterpump, hoses, heater core still the same but flushed out. Now I know it is going to be something stupid causing the problem. Have already checked for any disconnected vacuum lines and didn't find any, doesn't mean there isn't any. What could cause this problem. Entire motor was out so a lot was disconnected, may have missed something. Have been driving it and so far no other issues. temp stays steady with no erractic movement. Ideas??
