greasydonkey
ive put up with this for 2 years now and i dont want to anymore. its a 5.0 ranger 4x4 with a 3" body lift and 6" suspension lift. the heater core is new and its not plugged up. the radiator is a bronco2 unit. it runs at normal temp or just a bit below. it has an electric fan thats thermostatically controlled. i get no heat out of the dash. ive checked everything i can imagine. for all the other guys here with 5.0 engines and body lifts, have you found that with the cab sitting higher that water wont flow the slight incline upwards into the heater core? could that be the issue? if so, that doesnt explain why i had heat for the first few years after i built it.
any ideas?
any ideas?
