Newbe from Co.
Bicyclebuilder
South eastern Colorado
I am new here.:icon_welder:
I need information on a 1986 Ranger 2.9.
Having a problem with my water system.
I am loosing water. but it's not a leak,
I have NO water in the oil. or any oil in the water.
I replaced the rad, water pump, & freeze plugs.
It's not going out the exhaust, ether.
It runs fine for 10 to 15 miles, then over heats.
I use 50 - 50 antifreeze,
Can some one tell me where my coolant is going?:icon_thumby:
Could be a freeze plug or gasket. Do a pressure check, odds are you are losing coolant only when the system is pressurized...
SVT
Only if its leaking. A coolant pressure test will tell you...
SVT
