It does.
This is why a (properly tuned, and in good shape) carburator would atomize fuel better then any EFI system, besides TBI. The fuel had to travel a long distance through an hot intake manifold to reach the cylinder.
Yes, that is why EFI runs so much cleaner and more efficiently across a much wider range of conditions than any carb ever could.
Face it, carbs suck and it isn't just because of the venturii effect. There is no metric by which they are superior to an EFI system, especially an OBD2 one, and the only reason we used them for as long as we did is because that was the best we could do with the technology we had.
Carbs atomize fuel in exactly the way Rusty says, and it works. They push low pressure fuel into the jets and let the heat and distance atomize the fuel. That is also why there are performance gains to be had by using a throttle body spacer with a carb.
EFI does it differently. It pushes high pressure fuel through 3 or 4 smaller openings right at the valve. This is actually a very efficient way to deliver a precisely metered amount of fuel to an individual cylinder and, generally avoids issues like fuel pooling in the intake, cold start problems, and uneven delivery.
Most carbs run fuel pressure between 5 and 10 PSI. Early EFI systems ran about 35, and modern ported injection runs around 70. GDI systems can have upwards of 3000 PSI at the injector. Going from high pressure to low pressure through a small restricted orifice does wonders for atomization.
GDI systems do have issues with carbon build up on the back of the intake valve because on a ported system the injector spray does wash the valve. This is why early and frequent induction services are important on GDI engines. It is also why a lot of manufacturers with GDI are starting to use a "dual fuel" system where they have ported injection running when full power is not needed, then switch to the direct injectors at high load.
