I tried the Pittsburg Pro ratchet on my Proto sockets at work. Fits fine. I am think it was a combination of sloppy tolerances on the PP ratchet and sloppy tolerances on the Huskey sockets that made them not fit together. I'm going to daily drive them both for a while and see if I notice any other differences.
Is there a Pittsburg Pro left handed ratchet?
I need to find a decently reliable AND affordable digital or click style 1/4” torque wrench. Preferably one that goes down to about 10in-lbs. every time I look at them. I don’t recognize most of the brands I’m willing to pay for.
I borrowed an inch/pound dial torque wrench to check the pinion nut on the differential. That was nice and easy way to measure the force needed to turn it. It was a Starrett. Don't think Starrett makes them anymore, but other brands do.
I have a cheap beam style that I used for that purpose. I would like something better for use with the small metric screws on my motorcycle. They are mostly threaded into expensive aluminum pieces like the engine casing.
Just found a different Tekton model on Amazon. It’s in my basket. $43
I have had good luck with the tools from Eastwood, you may want to try them as there are a few inexpensive torque wrenches.
I have 2 from there & have no complaints.
From what I understand the precision follows a bell curve. The top and bottom of the range aren't nearly as accurate as the middle. Try to find a wrench where your target is in the center of the wrenches range.
