New Guy Here...
Troy94
Ohio
I have a 3/4 lower (semi-custom...):headbang: was just wondering if anyone could help me figure some stuff out with the alignment of my truck.
Its my daily driver so i can't afford to keep putting tires on it...
Anyone care to throw some advice my way??? It would be greatly appreciated thanks
Well how is it lowered in the front (I hope by semi-custom you didn't cut them coils :sad:) but you should start with getting some adjustable camber eccentrics and see if that helps.
yes i did =( but i have some'2inch lowering coils" from summit
but... where would one find these "camber essentrics?"
The best ones I've found are at Napa and were pretty cheap compared to any place else.
a 3 inch coil drop is pretty much maxing out the alignment. your best bet is to get the +-4 degree camber caster eccentrics from napa part #264-3950 and then take them with the truck to an alignment shop.
thanks for all the input guys
this is my first time on a forum and it proved to be extremely helpful
i will let you guys know what happens after i get all the parts and such
thanks again
