New guy from Oklahoma
Danger_ranger83
Ada, Oklahoma
How's it going guy? Been doing some searching here for a while now while working on my project. This one prolly will be hated on by many as it's not a ford powered ranger..but not your plain SBC swap either
Here's some pics of the truck
And here's the power plant...I custom built the harness and headers. It's a pretty much stock 6.0
Here is a link to my build thread-http://www.ls1truck.com/forums/lsx-truck-conversions/31368-5-3-ranger.html
Welcome to the forums, yep not fan of mixing brands but you will fit in just fine here. blackwidow and doorgunner are fellow SBC swap fans. I dig the black on black look and the cobra wheels. Looking forward to seeing more of that truck.
This isn't about making what someone else wants it's about what you want.A six liter vortech is going to be quick.What are you running for a tranny and is all the wiring in?
Welcome to TRS :bye:
I dont see a problem with running a GM engine, i bet that thing hauls :headbang:
My brother knows someone with a 50's ford truck, it looks beat, all original paint and such, but it has a 5.3 vortec from a 08 GM truck. He says it flies down the interstate.
The engine harness is the stock harness out of the truck I got my motor out of I reworked it myself to make it a standalone harness. I only use 3 wires from the ford harness a constant 12v, a keyed 12v, and a ground
check out non-rbv builds and look up gwaii and his gt12 build he's our resident mad scientist here at TRS.:icon_welder:
What I meant on the wiring is is it all in there and the motor runs good.Im not saying you but a lot of people couldn't make that work.I have a friend who has an 03 6.0 1/2 ton it's pretty fast that Ranger should haul.Way to put the danger in the Ranger.
Well on the harness I'm not exactly sure yet..I've had some issues with it..I think it's just the fuel pump but as soon as I get the pump in I'll be able to run some scans with HPTuners and see if everything else is working the way it should
