RangerRich96
I recently replaced the fuel pump (about 2 months ago) in my '96 due to low fuel pressure and truck running lean. Truck ran great after replacing fuel pump, but then got sidelined due to a rotted out trans cooler line. Today I replaced a section of the rotted out line and went to start it up and it just cranks over but won't start. I hooked up my fuel pressure gauge did KOEO test, 0 PSI. I got out and tapped the gas tank with a small rubber mallet re-tested KOEO pressure and it went to 30PSI, then proceeded to start it up and it fired right up. However, after about 15-20 seconds or so pressure slowly drops and it idles down and dies. Hit the tank again, same thing, fires right up but then dies. I'm wondering if it's a connector within the fuel pump assembly or perhaps the harness above the tank? Any thoughts? I'd hate to have to pull the fuel pump again. This is a brand new Delphi fuel pump/sender assembly. Any pointers or thoughts really appreciated?
