greaseyfingers
Bought a 1990 Ford Ranger 4x4 that has a bad, front-passenger side, drive axle shaft
The drive axle shaft is loudly spinning within itself, which I assume is a stripped out, splined connection contained within a rubber boot, nearest the outside of the differential carrier, on the passenger side
Has anyone else had this problem, before
What's the easiest way for taking apart and replacing the drive axle shaft that's failed
