cowboycowboy91
- Jul 21, 2015
- Oklahoma
- 3.0 V6
- Automatic
- Total Lift
- 4"
My brothers 1992 ford ranger 4x4 had the transfer case bolts back out and fall off. The entire transfercase fell down and busted a chunck of aluminum off of the tail of the trans. It is a 5 speed standard trans. Anyways, there is 4 bolt holes on it, but no bolts for comparison. Does anyone know the bolt size to fit it? The truck is setting by a road and a cop said it needs moved by tommorow. I will have to pull the driveline off and drag it if I can't find out what bolts fit it. I could just go buy a handful and start trying them, but I figured someone on here might know. Also, I wanted to ask if that chunk of aluminum missing will hurt anything. There is a seal on the output shaft of the trans that should keep it from leaking fluid...right? It might let dust in there though.
