- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Ok...Getting really flustered here. I'm looking for ideas.
Basics: Picked up a decent shape 89 BII with just about zero rust. Main issue I was told? White smoke from tailpipe, might need a tune up.
We took care of the white smoke, new heads from world products. We have zero sickening white smoke out of the exhaust when it is warmed up.
It did have a pretty severe issue with how the engine runs, figured it might be cleared up with a full tune up along with heads. Nadda.
What is it doing? In a nutshell. Cold Blooded, hard to start when cold. Once started? Shakes quite a bit. Does not seem to be mis-firing or skipping, just has the shakes? (need to double check motor mounts---but that's another issue to be resolved) Keep in mind EVERYTHING listed for what it's doing? Was also doing before I re-did the heads and resolved the cracks into the exhaust.
When it's in open loop, or closed loop the engine does the same thing. No power. After a short while, when it hits closed loop? The idle seems to settle down a bit--still rough, but better. Put it into gear? Idle drops to about 650ish for RPM. (hard to tell, dash-tach always reads about 2500 regardless of what the engine is doing) It's actually fairly smooth just sitting at that idle in gear.
Now in gear trying to get it to move? It bogs down extremely bad and tries to stall out. This is not on the road at this time, so our testing track (for lack of a better word) is kinda short? However put it into gear--hit the gas? And it just starts to shudder, bogs down, just sounds real sick. We put it up on a set of ramps for a test I'll list below, it barely made it up the ramps--all the while with some detonation/spark knock kicking up at a pretty good rate. Anything that puts this engine under any load? It buckles. Now it DID do this before the tear down! Just want to ensure no one states this is something I did while doing the heads-- (before anyone suggests it? new thermostat installed correctly as well)
Things we have done:
Compression Test: 180lbs average on all 6. None below or above a 5lb difference.
Full and complete ignition tune up: Plugs/Wires/Cap/Rotor/PCV/Fuel Filter/Air Filter good. Timing is set correctly! (yeah..I know how to use the SPOUT) With spout connected? Computer appears to modify timing accordingly. (had one small 'bounce'...but that's probably due to my super cheapo timing light having a hic-cup)
Replaced broken o2 sensor. Yeah...when the PO changed the transmission? He snapped the old one off the pipe.
Full test of Fuel Pressure Reg: 40lbs at start. 34lbs at idle. Reacts/Responds with a vacuum pump attached normally. NO fuel in the vac line.
TPS tested and working normally: 4.97 VDC at pins 1&3. Did sweep test using meter. Normal, no jumps or dead spots. Base line throttle closed? 0.93VDC
MAP sensor appears to be working: Hard to test, 4.97 VDC going in. Mid range steady voltage at pin 2. Suspect this uses a generated frequency to the EEC. Engine stable at 15 inches of vacuum applied (go figure? Correctly timed, and the best it manages is 15-16 inches of vacuum?) Go slightly higher/lower--and the engine starts to idle rougher. More then 4" difference from base line? Stalls the engine. Vacuum line is good.
All vacuum lines have been checked, PCV hose replaced due to some nasty cracks. No vacuum leaks detected. I expect none created during the install of the intake/heads--as this problem existed before the tear down.
Dropped the cat's and examined the converter material. A bit of carbon, but you can see through the honey-combs using a shop light. Nothing to suggest any clogs. Further note: We did a quick run test with the exhaust 'off'..same problem.
Computer codes: KOEO: code 11-system PASS.
KOER: code listed "BOO" test.
No codes stored in memory, kinda expected that--we had the battery unhooked for a week.
The computer does control the timing, as shown by the self-test. Goose test at first did kick up a "Rich" error at the O2. However we re-ran the test 3 more times, and only generated the "BOO" error. (when in the heck do you hit the brake pedal for that brake on/off test???)
If you can read this? Glad you stuck around!!
At this time I am totally lost and clueless. The computer seems to be "happy". Nothing is blocking air-flow?. The module on the disty appears to be fine--good spark and the computer does manage the timing.
Everything I've done, is considered basic maintaining the system. (the disty cap was factory---) And I've tested everything I remember how to test LOL. I'm a far cry from my tech's day as a mechanic---but this one has me totally confused?
The only things that might be clues? 15-16inches of vacuum on a correctly timed engine seem a bit low to me. Our '75 F250 manages at least 18-20!. Give this engine any load and some gas pedal action? Vacuum bottoms to 5". That's why I dropped the cat's, thinking a clog in the works.
I'm almost tempted to think the timing chain might have jumped a tooth--Or something else fuel related? Timing related? **shrug** I'm just not sure? I know the disty went back in exactly where it belonged when I removed it--lined up 100% with the marker lines I made, and the engine was not meddled with during the process.
I'm open to ideas on what/how to test....more or less how to get this ol' girl back to running normally. My job is cutting back, so I lose the company van--and I can't afford to drive the '75 F250 back and forth. (360 2bbl...runs great--but crap fuel mileage)
I'll be working on it again probably on Thursday and/or Friday to figure it out. I can't afford to much more $$ for throwing parts at it, so I'd love to get feed back on what/how to test--
Ideas welcome!! Thanks!!
S-
S-
