- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Welcome to my world.
Nice place...but who did the decorating?
S-
This thing is under my skin at this point.
Call it a "Quest" LOL.
I've ordered in a "Kit" including new o-rings/seals....and most importantly? The mesh filter. Not to bad of a deal, $18.00 for the kit, includes 7 of each item (in case one gets screwed up, there's an extra)
I'm going to attempt to get the injectors a good cleaning out. From the looks of it? Just the main rubbers and the filters should ensure 4 of them will work out. The weepy one? And the other one (just for giggles and grins) I'll give a good soaking in carb cleaner to de-gunk 'em. The website suggests soaking to remove and loosen the crap. Then come up with a small DC supply of some type in order to "fire" the injectors while hitting 'em with compressed air and carb spray. That should be more then enough to reverse blow the gunk out of 'em.
I've got a 7vdc supply, not to much kick...and I did a fast test with one injector I brought home with me. It fires the injector normally, even if it's a bit under powered. It'll do to allow me to clean things out.
We are talking a very large amount of rust/scale/gunk built up in the fuel rail. I'm hopeful that just hosing it out with carb cleaner with the injectors all removed will clean things out. If I had to guess? The truck was not run for quite a while, in order to get things that bad. Gas normally prevents steel from rusting inside-out..So I figure get it cleaned out, and fresh fuel..
Well...I'm off in a holding pattern until the injector "repair" kit comes in. Wish I could afford to just go with new ones. But at around $40bucks a pop? That's $240 I need to use towards front brakes and two tires.
S-
Yes, this is quite methodical, and one of few bona-fide plugged injector problems. Very clearly so, I might add. It's hard to argue with a rustbrick sitting on a workbench (and it kinda sounds like my RABS valve).
I'd suggest trying to find out where that rust came from. Replace whatever is rusty on the inside. You might get lucky at a junkyard -- I've seen 200+K mile 2.9Ls over 20 years old with bright shiny fuel rails (on the inside). I'd be afraid the tank was full of gunk. Of course replace the fuel filter. Probably replace the sock on the fuel pump if there is a lot of crud in the tank.
I would definitely replace the injector socks and O-rings since you clearly have the skills to do it, and the supplies are on their way. 2.9Ls don't cut injector O-rings like 4.0Ls do (aluminum fuel rail with not enough chamfer -- Vaseline works).
What's a RABS valve's function and where is it located?
