Need help with wiring efi 351w
94BIGFOOT
n Royalton
I am building my 94 ranger I have done a frame off build. Is there anyone close to me that could help me wire the motor harness.? And get running. . I have a 94 lightning 351w mated to a zf 5spd I have all the lightning engine harnesses. Any help greatly appreciated wiring is not my expertise . Thank you any help appreciated
You should post your location when looking for help locally. No one will try to look up where you are if you don't tell em.
you in ohio?
is the lightening speed density?
i am in the middle of moving right now, but i might have time afterwards as we were laid off.
Swap in
I am in North Royalton ohio 44133 , Any help greatly appreciated. Yes bobby it is a speed density
not sure if i can make that ride.
the sd systems are basically the same as the regular trucks but double shot the injectors iirc. i have to see what i have here in the shed. i think i may have a 92 harness somewhere, i did a maf sefi van harness not too long ago and pinned the box off of it.
the lightening used the e4 so you may want to have the pcm chipped and tuned for the manual application.
you can probably back door it through the coils power to get it running and leave it stand alone....just hook up its powers and grounds, i cant remember off hand how they were....there are differences but its been a long time since i messed with that particular critter.
are you using the stock manifolds, hipo, or the comet style manifolds? or headers?
o2 sensor placement can get to be a pia.
