2.3L ('83-'97) Need help with hydraulic throw out bearing
00fudd
Washington
So I wreck my ranger a bit ago, and I had a 1970 mail jeep sitting around, so I pulled my lima out with transmission and transplanted it in the jeep. What I need help with is the hydraulic line I need a treaded end to go into the clutch master cylinder witch is under floor, the peddles come from under the cab. I can't use the stock clutch master because of the extreme angle on the firewall I'll never get the peddle and push rod straight. So any advise
you will probably have to have a local hydraulic hose place make you something since those are pressure lines
