Need help to ID cab plastic trim pieces.
Oxxon
Brownsville, Tx
2.3 (4 Cylinder)
I have a 2002 XL Ranger Reg cab and I'm looking to replace missing and broken trim pieces. For the life of me I can't remember what these parts are called so I can try to hunt some down. The driver side is missing and the passenger side is broken. Any help will be appreciated.
I always called them sill plates. Others might use rocker cover.
Piece you have highlighted is called a threshold plate, and the larger piece next to it is called a door sill plate cover.
Grumpaw
i call them kick panels. its where i tap my foot before getting in to keep all the sand out. sand has wore holes into my floors on almost everything i drive. ? living in florida is rough. ?
Thanks for the responses. I found what I needed with your help.
The kick plate is the one in the foot well below the dash, outboard of your feet.
i know. i call them that anyways. i have had several discussions on the subject. because i dont kick it ? i call what i actually kick, the kick panel.
