modelageek
- Jan 31, 2009
- Boston, MA
- 4.0 V6
- Automatic
. It also said misfire cyl. #1
That is a p0301^^^^^^
Sent from my SM-G900V using Tapatalk
what 0301? never pulled that code. it pulled p1131. did change one upstream o2 sensor, but not both. should i also replace the other o2 sensor? truck is no longer recording any codes.
No it did not code a #1 misfire, it was #2 and a lean condition on right bank. have replaced everything except the can purge valve. cleaned that though, and it wasn't very dirty. haven't cleaned the canisters mounted above the spare yet. have replaced all fuel related parts, and vacuum parts. there are so many i don't really feel like listing them all. both upstream o2 sensors have been replaced along with opening up the catalytic converters. None of this has helped. Have even disconnected the battery for 5 minutes to attempt to reset the computer. Just for the record, I am a woman, not a dude. Thanks for everyones input. Still trying to figure out the problem.
Did you change the EGR control solenoid? Be sure and bring the engine up to temp before any testing. The computer will run at open loop until the engine reaches around 140 degrees before any of the emissions systems begin to work or goes closed loop. Just in case you were not aware of that. Disconnect the battery for at least 1/2 an hour take a jewelers screwdriver and push all the pins in on all the connectors both sides. Make sure all the vacuum lines are correct and everything is connected. Inspect all the wiring especially around the exhaust manifolds for bare/ cracked or broke wires and fix as necessary. Run the engine at least 20 minutes at medium speeds, in all gears, cycle heat and A/C and then pull the codes again while the engine is still hot.ok went out and started truck, pull vacuum off egr and nothing happened. then pull vacuum off the egr solenoid, nothing happened. then pulled vacuum off the can purge valve, and the idle went up, but truck did not smooth out. disconnected the wires from the egr solenoid and nothing happened. any ideas?
have you checked compression?
is idle rough or does it go up and down?
If you have a misfire code on a 3.0 do a compression test on the cylinder. Disable the motor from starting when you do the test. Post the result.
Hi Jinxlee. Sorry but had an inner giggle because I've been going thru same with my husband's ranger. Well, we also had misfire #2 (p0302 flashing check engine) and rough running symptoms....and because of the misfire, other codes o2 sensor popped up too. We had changed plugs,wires, then we checked and swapped coils, checked the injectors, changed vac. hoses, pcv, fuel filters, cleaned MAF throttle body etc etc..... Was sure it was IT each time, as each part we pulled was bad or faulty, but no avail. Finally did compression test. BAD compression #2: not exactly sure of numbers, but something like 130-45-130-130. $850 later, I wish we would have done it sooner. Now, to get valve job or ?? At least we know.
Did you check your PCV valve? Mine was rattling, but saw the spring was weak or broken. Also I read do not mess with the curb idle screw. I know my guy was increasing the idle, but I backed it off afterwards and reset the computer because I was coming up with a p1506 (Idle Air control system overspeed error).
p.s. My friend who has been doing the work on the truck (99 2wd 2.5) also had a Ford mechanic come help with diagnosis. After the plugs and wires were changed, the top thing the ford guy wanted to look at were the 1) coils 2) injectors (had a tool and fuel pressure gauge) and 3) vacuum leak (which we had 2 bad hoses, but still didn't solve)...he was pretty sure it was a vac leak. Final test was a compression test, let me know what you come up with, I'm in the same boat.julie
