jinxlee
- Jun 9, 2014
- Atkinson, NC
2004
- Automatic
- My credo
- hard times don't last, strong people do
I have a 1999 Mazda B3000. It runs very rough at an idle, and if you give it fuel, and then let off it will die. It pulled the code P1131. It also said misfire cyl. # 1 and lean condition. So far, I have put in new plugs, wires, injectors on that bank, coil pack, O2 sensor, MAF sensor, fuel pump and screen, fuel filter, egr valve, pcv valve, egr position sensor, and new vacuum lines. None of this has solved the problem. When you pull the vacuum line off the egr control solenoid, the idle goes up, and the truck seems to smooth out. Do I need to replace the solenoid, or the canister purge solenoid. They are both mounted together on the body on the drivers side of the truck. The canister purge solenoid has an air hool up and says only 1psi. Can I try to blow that part out, and see if that fixes the problem? Can I try to clean both the egr control solenoid and the canister purge solenoid? I'm a little tired of putting new parts on the truck and nothing seeming to work. Also opened up both catalytic converters in case they were plugged up. I will replace them soon, as that also did not help the running condition of the truck. Please help, truck is driving me crazy!
