Brandon's 4.0OHV
- Dec 27, 2015
- Automatic
So I got a 94 with the a4ld, I bought another one that should also have an a4ld but doesn't use the same filter. Is this new transmission a bolt in or is it a newer one? Everything else looks near identical just different filters and the tail shafts are just a little different .
Pictures aren't uploading from my phone give me Second to work that out but the numbers read on the original transmission: tail shaft( P92GT-7A040-AAR ) and the tail shaft on new transmission reads ( P95GT-7A040-BAR ) the throttle bodies and connections all look the same and read be same numbers. Thanks in advance for any clues. But the filter I took off this new
Transmission is labeled for a 95 not a 94. Does it matter ?
