Need help finding something...
06RangerXLT
Georgetown Ontario
what do i need for a power door swap. locks and windows. the doors with everything installed, and im guessing there is a lock control module. where is it located? :icon_confused:
any other systems needed to run it? modules, fuses, you know. i can run power for windows, but when it come to locks i have no idea.
:icon_thumby:
thanks
Most electronics such as those are controlled by the GEM module behind your radio.
Do what i did. wire your power windows with a relay. way easier. that way u avoid wring up the factory module.
u can get oem actuators and switches, or universal actuators, and oem switches, to keep the factory look.
just be sure the actuators are for the same year as your doors. or that they fit the non power door.
the power mirrors is a piece of cake. just get a 12v line to the switch and wire the mirrors. theres 3 wires for positions and thats it. no relay needed.
locks, id go with aftermarket ones, like i did on on mine, since the ranger ones involve replacing the whole door lock mechanism.
also, the aftermarket ones can be wired on relays.
