The_Dealer
well ive decided im going to get a full gasket set to fix most of the leaks that i have. i have alot of sludge and other crap in my motor so when i take it out im going to clean the heads, get a p&p done for the heads and intake, and get a cam kit with new lifters to replace my worn out ones. also going to do a new oil pump, fuel pump, freeze plugs, and im going to do a cam while i have it all apart. which one of these cam kits would be best with a 1800 stall and a4ld?
http://www.summitracing.com/parts/CCA-CL38-240-4/
or
http://www.summitracing.com/parts/CCA-CL38-101-4/
or
http://www.summitracing.com/parts/CCA-CL38-241-4/
also i have a broken valve cover bolt, a little is sticking out above the valve cover, i think i can get some vice grips on it with the cover off. is there a better way of extracting it? also i have a stripped bolt hole on the i/m for the v/c bolt as well, how do i fix that? anything else i should do since i have the motor out?
or
or
