- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
There should be a tag somewhere listing the ratio (either a yellow & white decal on the backside of the passenger beam, or a metal tag on one of the front cover bolts)
Lacking that, look on the side of the ring gear itself for a stamped-in number such as "41-10" indicating the # of ring and pinion gear teeth.
Last, you can try checking it by counting the # of turns of the pinion for one turn of the differential carrier (4.1 turns = 4.10. 3¾ turns would be a 3.73, and so on).
