lindburly
I have a 97 4.0, 4wd Ranger with manual trans.
The previous owner had put in a clutch meant for a 3.0 and I had to get both the clutch and the trans. replaced. Purchased a rebuilt trans. from Zumbrota Drivetrain and had it professionally installed. It lasted 4 months before 2nd gear went out. I got another one from Zumbrota and now, after 12 months (no longer under warrantee) it is popping our of 5th gear when under any amount of load. All the other gears are fine. I suspect a worn 5th/reverse fork and/or worn slider, both of which can be serviced by removing just the tail section of the trans.
It seems to me that it should be feasible to fix this myself by pulling the transfer case and removing the tail of the trans. housing without pulling off the whole trans. After studying all the material and videos I can find on rebuilding the M5R1 trans. I think it should be possible to do it that way and would save a whole lot of work and expense.
All of this assumes that I will be able to remove the top cover of the transmission through the access panel in floor of the cab. Can anybody confirm for me that access panel opening is large enough to do that? My understanding is that I will have to engage 2 gears through that panel in order to lock the trans. so I can loosen and then tighten the big nuts on the output and counter shafts. The other challenge will be removing the pressed-on bearing on the output shaft. I would lever it out by tapping the inside edge of it with a dull chisel as I rotate the shaft as shown in this video:
. (I would reinstall it by tapping on a piece of pipe held against the bearing. It looks like the removal and reinstallation of the rest of the parts should be fairly easy from under the truck.
Anybody have thoughts on whether I should try this? I know removing the transfer case is not going to be fun.
