2.3L ('02-'11) NEED ADVICE/HELP!!! low compression on cylinder 3 :(
hannah2001
Forum Member
Georgia
2.3 (4 Cylinder)
my 2002 2.3 253k miles developed a severe valve cover gasket leak around the same time as a cylinder 3 misfire. i figured it could be oil leaking into the spark plug hole and maybe fouling it out, so i put new valve cover gaskets along with brand new motorcraft plugs, wires, and a new coil just to be safe cause i have never changed them since ive owned the truck.
put everything back together and no leaks, but the cylinder 3 misfire remained so now i started to worry. hooked up a compression tester and cylinders 1 2 and 4 have around 200 psi (i think thats high for this motor but my gauge might have been reading high idk. main thing is all 3 readings were very close to each other) cylinder 3 read around 80 psi no higher. i put oil in the cylinder and retested it and it read around 200. from what i understand that means its more than likely piston rings. i'm not a mechanical genius but i do know a lot and understand a lot so please correct me if im wrong on anything.
i drove it for about 2 weeks with the misfire while i was thinking it was just spark plugs. the misfire is not TERRIBLE, it got me to work and back etc. but im not happy with the results. now im looking for advice and guidance on the best route to take to get it fixed
1. IF THE PROBLEM IS PISTON RINGS, just assuming by the results with the wet compression test, if I put a thick oil in it or something like engine restore, would it help seal the rings enough to where i can keep driving it to work and back? about 20 miles a day and i live in middle georgia it is very flat no big hills. what about disconnecting the cylinder 3 injector and just driving it on 3 cylinders? would this destroy it past the point of it being rebuildable?
2. i've never been in a situation like this, is it generally a better decision to buy a remanufactured motor or take my motor to a local rebuilder? im scared of remanufactured engines especially from mass sellers because i hear so many bad things about them not lasting at all and then when they fail within the warranty period you have to basically pull teeth to get any help. just say powertrainproducts.com for example.
3. im very mechanically inclined, i do all my own repairs and have done just about everything myself except rebuilding motors and transmissions, i have all the tools necessary and if not i would buy them. is it realistic for someone like me to rebuild the motor in my shop at home?
thank you anyone for any advice. this truck is sentimental to me and i want to do everything i can to not junk it.
1- Theres no mechanic in a can. You can try it...but the chances of it working are pretty slim.
2- I would have yours rebuilt by a quality shop. Remanufactured onea can be a crap shoot
3- Besides the machine work...yes you should be able to do it at home.
do you recommend somewhere to buy good quality rebuild kits? there is only one by enginetech on rockauto but its out of stock no idea when they will get more. there is one on proenginebuilders.com, partsology.com. i wouldnt know which one to go with if i decide to rebuild it.
i just want good quality parts because I got 253k miles out of this motor i would like to get 253k again or more
same thing happened on my 2005 2.3 only it was #1 that lost compression.
the rings just wear out/lose tension and stop working. no compression and lots of oil fouling on that plug.
I swapped in a used engine.
FYI, these engines do not have timing keys of any sort. the cams and crank are held in place by special diamond coated washers and friction.
merely loosening the harmonic balancer bolt means the engine needs re-timed.
about the only special tools are the crank stop-TDC bolt and camshafts alignment bar. can't remember exactly, but the head bolts may be an odd size.
For grins and giggles, try Valvoline Protect and Restore. If it is stuck rings you are dealing with, that will clean out the ring grooves to loosen them up. The trouble is, it will take at least four oil change intervals as per manufacture recommendations, so, many thousands of miles.
It'd really be in your best interest to replace the entire motor and not just focus on the rings/bottom end.. as the limas are somewhat prone to both developing cracks between valve seats AND suffering from depressed valves.. and at a quarter million miles.. that heads seen it's fair share of duty.
A reman 2.3 long block is right around 1400 shipped from MAABCO motors in texas. You're right about reman outfits having so-so reviews.. but I know plenty of machine shops in my area that suffer from the same hot&cold reviews so... Just going to a machine shop doesn't necessarily put you in any safer of a position.
It's a good idea..if you get a reman.. to blow the thing most of the way apart before install just to check torque figures on everything and then replace it's gaskets&seals with ones from felpro or some other quality company. A lot of the bad reviews I've seen from reman outfits stem from internals not being properly torqued.. seals that have been installed by a gorilla.. and crappy gaskets.
Any way to check spark at #3?
I know with the mod motors, they get fluid into the plug wells, shorts out the ignition and damages their dainty little coils. I don't know anything about these but I would cover my bases and check for good spark.
It would be a bummer to swap motors and still have a #3 missfire...
Compression is low but if it has been driven without fire in that cylinder it has been washing the cylinder with fuel. Injector needs disconnected (electrical connector) until you get this sorted.
If I was in this situation . . .
I'd see if I could find a GOOD used motor, preferably running, or even able to be driven, before the purchase. Do an engine swap to get the truck back on the road, and hopefully that will buy it a lot more miles the quickest and easiest way.
And, I'd also look at doing a rebuild on the original engine. It will have to be disassembled, and assessed anyway before reusing it, and before buying parts. With low compression on one cylinder, you want to measure the bores and obviously look for scratches, to determine if you need to have the block bored and use oversize pistons. Same applies to the crankshaft, to ensure that its journals are still in spec. In other words, put together a good short block from the original, if it checks good and is machined (if and where needed), and just go with a new head, parts loaded and with a good warranty. New accessory items (especially the oil pump anyway) as needed.
That would be the right way to do it, to have a "zero mile" engine; you'd have the luxury of time, and the time to learn about what you're doing. Throwing parts into a block that hasn't been checked properly, is a gamble at best and a waste of money at worst.
The experience itself would be worth it, and the knowledge gained would be very valuable to you down the road.
Whatever route you go, I wish you the best of luck!
A very simple mistake blew this engine. My heart sank at the reveal because in different ways, I've made those mistakes.
You posted this Monday and I actually already went and bought a used motor Sunday 😂😂 so its kinda too late now but just for giggles i will go back and check spark because i havent pulled the motor yet
Just now seeing this post and this is exactly what route I ended up taking. I got a 150k mile motor for $600, complete with everything on it and compression tested it before I bought it. I'm gonna swap motors just to get my truck back on the road and i'm going to attempt to rebuild my old one. Since the truck will be running i wont be in a hurry rebuilding it
I have never rebuilt a motor myself before, i do have someone experienced that said they would be willing to help me
I will be taking the block and head to the machine shop for all necessary machining work
If anyone has any advice about rebuilding this motor / rebuilding in general please let me know
Also please recommendations for good quality rebuild kits?
Thank you everyone
Just wondering why do recommend buying a new head instead of rebuilding my current one?
Bag and tag all small pieces as you go.
Take lots of pictures and put descriptions.
Buy yourself a Ford book manual set. You can sell it after for the same price or close.
Take your time...
Ask questions...
Good luck.
Rebuilding may cost you the same if more than remanufactured engine. Most likely the piston rings in this case. Especially after 250k + miles. Also any work on the top end may not translate well to bottom end over time due to the enhanced performance and compression (if top end is successfully worked on). You may begin to hear knocking and just hate the performance over time. Think of it as giving a track runner someone else’s used shoes. Most mechanics would be hesitant to do any valve job or top end maintenance given the mileage of the vehicle ant this point, and if they did take the job without warning you of the drawbacks? They wouldn’t be trying to save your wallet or your mind from further heartache.
At minimum, IF all that the head needed was disassembly, inspection, cleaning of parts, minimal machining (valve seats and lapping), stem seals and reassembly, then great.
But at 253k miles, you may very well be looking at some (or most) of the parts needing replaced, maybe more extensive machining, and the casting itself will have to be carefully inspected for cracks.
When I last looked at rebuilding a Lima prices years ago, springing for quality reman head, assembled with all of its parts, was more cost-effective versus buying the needed parts and paying machine shop labor. I don't know if it's still true or not; but at least Lima was popular and made for many years, so parts are still fairly available.
It wouldn't hurt, to run the head question by the person helping you, and to ask the machine shop for their opinion. They may even be willing, to look your head over for a quick assessment, and may even have a recommendation for where to get a complete reman head.
That is great advice from alwaysFlOoReD; bag and tag everything, stay organized, and take notes. In this wonderful digital age, it's so easy to get a lot of pictures as you go; take more than you think you'll need. I highly recommend getting a set of the Ford manuals; start watching eBay, and you can end up with a set for not much money. You can always buy them at a high price on eBay, but they do regularly show up for a lot less cost but you gotta get 'em quick. Even the Chilton's type books would be helpful, to someone wanting to learn.
One other advantage, to going "turn key" with the head, is that you can better focus your time and attention on the bottom end, and on the rest of the motor (accessories, etc.).
