Need a GOOD wiring diagram of the 2.8 (1984)
OilPatch197
Yeah, yeah I know there is that copy on the tech pages, the exact copy I have in my book.
however it SEEMS to be wrong!
Does anyone have a BETTER diagram of the 2.8 engine ignition controls?
If you look at the TFI module at the tech info:
http://www.therangerstation.com/tech_library/EDiagrams/files/Diagrams_StartIgnition83to882_9.JPG
There is a Dark green with yellow dotted wire that goes from the TFI to the ignition coil, according to the diagram it splits off before it gets to the coil, one wire goes to the insterment cluster, while the other wire goes thru that Resistor to the ECM, according to the diagram they are ALL "dark green with a yellow dot" however I only have the one wire from the TFI, the other wires are different colors.
Hopefully can somone show me a diagram from a Chiltons or a service manual?
My '84 EVTM shows the Green/Yellow dots wire as just going straight to the coil from the TFI module, with no splits.
