Need a ford axle guru
Ozwynn
If you didn’t bleed for it you don’t deserve it
Berrien Springs, MI
MI - USA
If you can't go through it or around it, then go over it.
Axle code on the door is B6…. That should be 3.73LS. I’m getting conflicting answers…. Google AI says 3.73 and meta AI says 4.10LS
This is for a 98 LD F250 7 lug with a sterling 10.25 semi float…. I think… 12 bolts on an oval ish diff cover
