Need a ford axle guru
Ozwynn
If you didn’t bleed for it you don’t deserve it
Berrien Springs, MI
MI - USA
If you can't go through it or around it, then go over it.
Axle code on the door is B6…. That should be 3.73LS. I’m getting conflicting answers…. Google AI says 3.73 and meta AI says 4.10LS
This is for a 98 LD F250 7 lug with a sterling 10.25 semi float…. I think… 12 bolts on an oval ish diff cover
google gave me a forum link to someone with one of those that confirmed 3.73 and semi float 10.25
If still there there should be a tag on the rear axle as well that should read on the bottom row 3L73 1025 then some other digits that don't matter... top row is date code and such that also doesn't matter...
AI = "no intelligence" you would be wise to avoid that garbage.
B6 should be limited slip and it appears that that code may have been used to designate either 3.55 or 3.73 ratio. Most of what I see says it is 3.73. But one chart that comes up lists a 5300lb B6 axle with 3.53 gears. I would almost bet that is the 7 lug version. Is there a metal tag on the axle? Or, get the wheels off the ground and count how many rotations of the pinion equal one full tire rotation.
The post I saw mentioned that 3.55 thing as well and it sounds like the B6 designation switched from 3.55 to 3.73 at some point year wise
Don't listen to AI, ever.
Just this afternoon I posted a few questions to reddit about a dirtbike carb.. and now when you search things related to that model of carburator googles AI overview takes its "facts" from my 2 hour old reddit posts that have 2 incredibly vague replies a piece.
Blew my mind.
All I wanted to know was if my carb was a genuine keihin or a china ripoff, and made note that it was pissing fuel into the air box..
And yeah.. now you can Google keihin pb20 and the overview says "users frequently complain about the carb pissing gas into the air box"... Click on the link that cites their sources... Brings you right to my brand new reddit posts 🙄
Frequently is apparently ONE person first of all.. and second of all it IMMIDEATELY scraped that info and used it..
One way or the other.. this AI nonsense is gonna cook us as a species.
Blew my mind.
:iamwithstupid:
