Need a bit of input...
Yeah, thanks...will see what it is and what it needs today hopefully...if it's in better shape than mine and the motor runs then it might do until I can get the engine rebuilt...or may be good for some parts that I've been meaning to change/fix...like the box...
And if it starts in the cold weather without having to use battery chargers and block heaters (not a bad idea to have a block heater regardless) then that is a big plus...
Dang...it was a regular cab with a 3.0...many good parts on it but I need a motor...took it for a short test ride and it ran great...needs a new fan switch, drivers' window and door do not open...but otherwise in really good shape for a 92
If I win the lottery tonight I might just buy it and use the good parts...brand new tires on 14" aluminum rims (like the ones I have but a size smaller)...
:icon_confused: its a ford with a mazda badge.....mazda has nothing to do with it.
I dont know man,
1. the motor needs a rebuild
2. the body sounds like its shot
3. it needs some work done on the clutch
unless you get it for under 100 bucks it has no redeeming qualities.
i wasnt talking about newer mazdas, i meant older mazdas that dont even look like fords, but idk if they are the same thing at that point or not, they most certainly dont look the same.
