Need a bit of input...
Yeah, thanks...will see what it is and what it needs today hopefully...if it's in better shape than mine and the motor runs then it might do until I can get the engine rebuilt...or may be good for some parts that I've been meaning to change/fix...like the box...
And if it starts in the cold weather without having to use battery chargers and block heaters (not a bad idea to have a block heater regardless) then that is a big plus...
Dang...it was a regular cab with a 3.0...many good parts on it but I need a motor...took it for a short test ride and it ran great...needs a new fan switch, drivers' window and door do not open...but otherwise in really good shape for a 92
If I win the lottery tonight I might just buy it and use the good parts...brand new tires on 14" aluminum rims (like the ones I have but a size smaller)...
:icon_confused: its a ford with a mazda badge.....mazda has nothing to do with it.
I dont know man,
1. the motor needs a rebuild
2. the body sounds like its shot
3. it needs some work done on the clutch
unless you get it for under 100 bucks it has no redeeming qualities.
i wasnt talking about newer mazdas, i meant older mazdas that dont even look like fords, but idk if they are the same thing at that point or not, they most certainly dont look the same.
Upcoming TRS Events
Featured Ranger Based Vehicle
