Name that lift
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Millersport, OH
Can anyone tell from these pictures what brand these lift brackets are?
They are for 4 or 6 coils, and I believe they were on an 86. I bought them from a guy who bought a Ranger with them already on it. I already gusseted the tabs. :icon_welder:
-plumcrazy
Im going to have to say skyjacker since its a drop bracket and not a drop plate...
Skyjacker was my guess, just trying to see if anyone agrees.
-plumcrazy
Those are superlift. The Skyjacke rdrop bracket for the driver side beam(not the cast one) is alot beefier than that. That looks like superlift to me.
agreed wizkid i have a tuffcountry kit and the passenger side bracket is made out of plate like you said and the drivers side is shaped differently.
Must be superlift???
Looks to be alot stronger with the gussets....i may end up doing that same thing to mine WHEN it starts to crack/fail.
The passenger side bracket looks a lot like a superlift, however, the drivers side does not....
:dunno:
Note the cast lettering on the red bracket to the left. That was an early design. The later ones were narrower down at the bottom to allow more differential clearance.
My cast bracket looks identical to the red one in JohnnyU's pic, but it doesn't have "SKYJACKER" cast into it. It does have a "B" cast into the front, and "RHB 35-6" cast into the back. I beleive the radius arm drop brackets were also cast, but I didn't buy them because Im going make some extended rad arms anyway.
-plumcrazy
Those are both 4 and 6", hence the two different holes on the bottom.
I know why there are two holes. I am trying to figure out what brand they are. I got them used and I am curious to know what kind they are.
-plumcrazy
I'm not intending to be rude but, Why does it matter?
It doesn't really matter, I am just curious and figured that someone would be look at them and tell me real quick. I don't really need to know.
-plumcrazy
