My Truck Transformation - 94 4x4
Mission accomplished! Truck is back on its own weight and ready for an alignment. Had a heck of a time getting the old leafs out, had to torch both sides of both main eye bolts, thank god for torches.
A before pic for reference:
How she sits now:
Had to add a few washers to get the right amount of lift on my supercab 4.0:
So I'm guessing I have about 3.5" of lift now, which I almost needed in order to get the pivot bolt about 1" above the hub's center-line as is suggested in the tech article section.
Stats:
James Duff 3" stage 1 kit (the brackets drop the radius and pivot arms 2 inches)
about 1.25" worth of washers as coil spacers
drop pitman arm (drops steering linkage 2 inches)
"new" leafs from a 2006 ranger with only 30k miles on them
1" lift shackles
32x11.5x15 BFG's on 15x8 cragar wheels with 3.75" backspacing
James Duff shocks in the front (8108's, good for 3-4" lifts)
ProComp ES3000 (32650)shocks in the rear
Man my 32's look small now.
Do I need to go another 1" higher in the rear?
AAWWW Snap! That turned out awesome man!
outofstep, that looks like my trucks twin! good lookin rig ;)
Getting this thing aligned tomorrow, can't wait
And hit the trails today
The duff shocks handle GREAT, very good manners on and off road. Now I have to plan to replace the procomp shocks in the rear with some duff shocks... the wife is gonna be pissed! :)
Be careful with those tow hooks, I have the same ones in the same place and from being pulled out and from pulling out fullsizes it bent the bumper brackets outwards, now I have to replace and gusset them.
Thats good to know! I certainly won't be doing any "yanking" with these primarily because I woudlnt' want to tweak my frame either. I just dont see any cross member support up front, its not till you get back by the motor. I just hope they'll be enough to get a little pull if I need it or vice versa.
I was putting together a list of tools and parts to do my own ball joints, and I still might let the shop do it, but I figure I should have the tools to at least repack my wheel bearings. Haynes says to do it every 12 months/12,000 miles and I haven't done them at all :o So I'm on the hunt for a 4-prong spindle nut socket....
If you can put a lift on i think you can do ball joints. and autozone sells the 4prong tool.
Thanks eduardo!
I did pick up a 4-prong tool at the local NAPA for $15, so I think I'm good to go, just short a ball joint press. I know the guys at a local shop that I think won't mind if I take them the knuckle and have them only press out the ball joints... they let me use their lift to install my lift kit afterall :) So I should have the parts by Tuesday, so it'll be next weekends project.
Wish I had an autozone that wasnt 45 miles away, I'd certainly rent the press and do it myself.
Today its oil changes all around!
I would let the shop press out the joints, I had to take them my knuckles cause I couldnt get mine out
