My New House & Workshop
I get the need for GFCI, I just think the chances of that being an issue are much lower than anytime I fire up an angle grinder... there's arteries in all sorts of vulnerable areas near where I'm grinding... just as one example
Trying to find 8-foot LED shop lights is becoming a challenge. I want something with 8-foot LED light tubes, and most everything I see has the LED integrated. I don't want an integrated light. I want to be able to replace it if it burns out.
The 8 foot led's that I have seen, I am not impressed. Some of them are made of plastic and they sag. I never have personally messed with them, it might be they come with center supports that whoever did it, did not install.
The 4ft's are more common and cheaper. I actually use the LED 4ft bulbs you can get at Walmart. They work very well and are cheap. I have installed hundreds of the great value Walmart 4ft bulbs, and in the past 10 years I have not had one fail. I had a vendor want to start selling me LED's wholesale, and I told him what I use and the price, and he said he could not match it.
You used to be able to get 8 ft lights that took 4, 4 ft bulbs and dual ballasts. That is the one thing about the Walmart bulbs, they are drop in and do require a ballast.
Now the Great Value LED screw in bulbs, that is a different story. I was buying the 60w equivalent, and I have had a lot of failures with those. So much so I stopped using them and started using the name brand bulbs that Walmart sells. They are GE or Phillips, I can't remember which. I am having better luck with those.
P.S. I am also impressed on how bright the walmart 4ft leds are.
Home Depot has this 8-foot light that takes (4) T8 4-foot LED bulbs:
They have that same light with 4000k bulbs as well.
It's unusual they include the bulbs. I wonder if they use ballasts or direct wired bulbs? I kept going back and forth on it, I wired a whole house with direct wire, but then I started using the drop in that require a ballast. It turned out better for me to use the drop in, since it's quicker for me to install the bulbs 90% of the time, and I can even mix and match regular tubes and LED tubes. But it's whatever you want to go with.
That light from homedepot may just be a empty metal shell with sockets in it if it's using direct wire bulbs.
There it is.
My breakers, GFI breaker, and 40 amp double pole for the tankless water heater.
The water heater threw me for a second because it has a white, black, and green ground connection at the heater, but calls for #8 wire and a 40 amp double pole. So obviously both the black and white go to hot.
The GFI threw me for a second as well because it's so much bigger than a normal breaker. There I had to make sure that the white and black went to the breaker and the white pigtail went to the neutral bar. I cut off the excess pigtail.
There it is.
That thing is so straight and pretty, I would be tempted to use a piece of clear acrylic for the inner cover so I could look at it anytime I wanted to!
Nice work!
Nice work!
Thanks. I'm working on my Electric Subpanel Merit Badge
Nice work!
It needs lights around the edges like a gaming computer though.
Event Coverage
TRS Merch
