Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Manual
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Ok. Those are large units using a lot of electricity. They are using a separate breaker for each set of heating elements. I wouldntthi k you would need those large ones for just one or 2 sinks in a shop. If you're going to run a shower, the larger units would be needed. Furthermore, keep in mind the size of the total electrical service to the building. You don't want to exceed that or your water heater will trip the main breaker and everything goes dead.I could have framed in a 32x32 shower where this narrow brick wall is and then brought the end wall and door out even with it, but when I started calculating what it would cost me to do all that it didn't seem worth it considering the little it would get used. It also means I'd have to mount my small kitchen sink on the other side of the room in the top of my storage cabinets which would be more cost as well.![]()
@ericbphoto this is where I got the info about the wire and breakers:
@Shran thanks for the suggestion. Thos is the one I was looking at on Amazon:
EcoSmart ECO 11 Electric Tankless Water Heater, 13KW at 240 Volts with Patented Self Modulating Technology https://www.amazon.com/dp/B001LZRF9M?tag=959media-20
