- Aug 13, 2007
- Age
- 55
- Automatic
looks like maybe an old C3
You've got me, I thought you had all that figured outwell if i wanna add my ps later how would i add it?
I think the trans you have is the C-4. I should have 11 bolts on the trans pan, the C3 has 13. The C-5 didn't come out until '82'. As far as adding PS later, plan now, probably going to change a few pulleys. I'll dig up some old pulley arrangements and show all the different options, might end up with a three groove crank pulley depending on what all you want to run.
Dave
Lookin good!
I would clean that engine bay and get her all pretty before droppin the new motor in.
And I did see two Yota's in the background....![]()
murder is whats going to happen to your underwear when you get it out on the road with the 302.......
when i first cranked mine up you couldn't have wiped the smile off my face with a boat paddle.i wish i could have driven mine more with the tunnel ram setup,ran it around the pasture for about an hour to break in the cam and set the rings.went thru about 6 gallons of high test.did 2 drop the hammer at 20 mph in high 4x4 and almost s@#t myself.i still think my hand prints are on the steering wheel.
If you are running alt, fan (water pump), p.s you should be good with one belt.
You do not need a separate belt for each accessory
