My idea of a Shelby Ranger if there would have been one.
I'm looking for a rear sway bar for one..... know of any?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Ya that's a bit of a drive for a sway bar
I figured as much.. I just dont get why Grant doesn't fix the issue with a design change...
Probably just not any demand, and they probably worked just fine when the trucks came out and all the plastics were nice and new.
Ground down the edge on the black disk on the adapter... Took for test drive.. Still has a tad of rub but it's ok.. found curve entered curve at high rate of speed... ZERO body roll!!!!!!!! Truck is running really well speacially with the cooler air we are having here in Ga...
Not sure if I mentioned this or not but a few months ago I discovered that the fuel tank won't fill up at a gas pump... I filled it up then the next day I drove straight to the gas station and filled it up again.. It took 5 gallons to fill it up.... Total miles driven 5 miles. left the gas station and got the 400 miles I was use to.. and that was driving in the mountains
When I picked mine up, they used a "mic" to check it and he told me it was actually a little larger than 1". Not exactly sure by how much, but I wanna say he told me like 1.1"..
I Found a few bushing kits for the BII.. one is a 1" and one is a 1 1\8 inch...
Looks like the 7/8 I mentioned before is the front...
Which to buy??? :annoyed: :annoyed:
Measure it yourself. If you want something done right.....
