OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
'84 Ranger, the gauge always reads 1/8 of a tank or less with a full tank.
Okay, so I need to do this:
So to get to it, I would like to take off the bed, disconect/remove taillamps and wires, remove tool box, remove the three fuel neck screws, and remove the six T-55 torx screws.
and if I determine that the float is bad, I've read somewhere on this forum that you can order a new one from Ford, but does anyone know that part number?
There's an issue with floats sinking on these trucks. To test the sender, unplug the four pin connecter at the tank and test the resistance on the sender. if it seems normal rock the truck and the resistance should change slightly as the fuel sloshes around. If the resistance is within the normal range but does not change when you rock the truck, the float has probably sunk. If the sender reads open the sender has a problem.
To test the front part of the circuit you will need either a resistor substitution box or a few resistors, a 33 and a 47 ohm should do. connect a resistor from the wire that comes from the gauge to ground and see what the deflection is on the gauge. different resistor values should give you different readings on the gauge.
