lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
Thanks for the input!You'll have no problems with a rear locker while towing. You probably won't notice it. The one thing you do want to keep in mind though is that in turns at low speeds you are using only one axle shaft to push the truck. You can snap it.
The front can be locked as well. That does take a little getting used to. Every time you push the accelerator or let off on snow with any amount of wheels turned, it's going to wrestle you for control of the truck. If you thoroughly understand what it is doing, you will be just fine. What it's doing is unlocking the faster tire. You have to drive very gently. Honestly, you will do fine in 2wd most of the time and don't have any reason to just be driving in 4wd. If it's 17" of snow and you need 4wd, you won't notice the locker because it's going to be working. And you will love it. I'm locking the front of my crewcab when I get the axle in, no question about it. The times I need 4wd in the winter, I don't want to mess around. It's usually up the yard or in a field or on unplowed roads. You don't need 4wd on ice or plowed roads.
Looks like I'm going to see about getting a locker in the next couple weeks, already starting to feel like late fall around here...
