my d30 sas
how much did the swap end up costing you, if you don't mind.
axle 350.00
front springs 100.00
rear springs 100.00
high steer bracket 150.00
rear hangers 75.00
front hangers 100.00
still have to get a new set of front springs, the used ones i got are a little messed up, and have to get lift for the rear(can't decide on block kit or lifted springs)
Got more pics of it?
Please give us more details, ride height?
ride comfort?
ride heightm its hard to say as i had a rough country lift with the ttb.... i'd say i gained about 3" more. it rides great, a little side-side movement(front springs are a little too weak), working on building a track bar for it now, will see if that helps
For the rear, just slap the lift blocks in and see how she is.
got the track bar bracket made for the right side, just have to make the left side bracket and get it mounted and tested
Nice, please try to post more pics, im really interested on this.
what pics would you guys like?
welding up the lift blocks for the rear tomorrow, still waiting on the ubolts so i can level out the rear.
Basically your leaf setup. shackles and hangers, steering set up, height. stuff like that.
Uhmm...everthing...we here on TRS are picture whores and the more the better.
added more pics to my album. built my own front hanger with ruff tough speciaties spring hanger and 2x3 tubing and 3/16 plate, rear of front spring hanger is an 04 F250 super duty, springs are factory wagoneer 7 leaf. welded and reamed ranger pitman arm with jb4x4 highsteer bracket
the range of this thread is killing me.
Maybe its just me but the rear leaf mounts look a bit close to the ground IMO, not much ground clearance from them.
they can' get any higher....lol mounted thru the frame, probably looks low because the rear of the truck is sitting 3" lower than it is supposed to be(still waiting on ubolts from husky spring in des moines :icon_thumby:
good pics.
whats your tire size in inches?
thanks, i will post more when i get the rear up where it is supposed to be
tires are 265/75/16, need to go a little bigger...little better tire. i traded labor for these(work on a lot classic oldies for a guy in my spare time)
You need to sign up for a photobucket and host your pics so you can just insert them into forums for people...
just a friendly bit of info..
